Sharpening saws
ashtead
17 Jun 2008
Surrey and Gosport UK
This might be one where I should be on a classic boat forum however I just wondered it was worth investing in a Somax set having just reread an article inPBO. I have some old saws which to my knowledge have never been sharpened but any other old saws out there with a few words of advice? Looking at the article and a handy u tube vid it seemed a simple process but am I deluding myself and should I find a professional saw sharpener if such exists?
'''''''''''''''''''''''''''''' From a teenager i always sharpened my own saws but as the price of files rose & the price of having then sharpened by the saw sharpener that visited my joinery works to sharpen planer blades, circular saw blades etc dropped I stopped bothering. Nowadays it is just as cheap to buy a disposable saw. One gets a far better cut in many cases & saves a lot of time. My saw set is the same as a somax ( eclipse I think) after a couple of saws it makes my hands ache. If one sharpens one's own saw one can put play with tooth shape a bit to suit the work in hand plus add extra set at the same time if working on site with damp wood which can be handy.
Saws must also be " set "- the amount the individual teeth are bent to the left and right as you look along the cutting teeth.
A dying trade.....................
A modern quality saw is so cheap and so superior why bother?
Where have all the saw horses gone though ? Seems to me it's hard to find a saw sharpener now for reasons stated above re plastic handle versions. I was actually hoping someone might still be sharpening their saws or knew someone who did this?
I sharpened some old saws recently to use with the scouts. Used an angle grinder with a very thin disc. The Oberg saw files won’t touch the newer saw blades. It is time consuming.
For about a fiver you can buy a saw with hardened teeth and clever geometry that will cut better than any of your car boot bargains. So why bother sharpening?
If you think sharpening a saw is a simple process, then think again. I can but was well taught back in the days when Pontious was a Pilot in Harwich
Reluctantly, I must agree that sharpening a modern handsaw is not worth it. My latest is a Bahco with hardened teeth and it cuts like a dream and has remained sharp for years of intermittent use.
As a child, I lived next door to Mr Starkey, an undertaker and carpenter. He put his saws in a clamp and reset and filed each tooth every week or so. I loved to hang around in his work shop and watch him working. A glue pot was always on the stove. Sadly those days are gone.
Grinding with a cutting disc, a great H&S failure to be caught teaching scouts?
I have a "gentleman's back saw" given to me as a child which is my favourite. It has very fine teeth which I can sharpen but my Eclipse saw set is far too coarse to set it.
A hammer and a nail is suggested by the old-timers. Probably need a bit of skill as a catalyst!
I have something similar and sharpen it with a needle file.
I use it as a slitting saw and don't bother setting the teeth.
When I want a saw with set teeth to cut a clearance, I use a modern saw.
Must admit it gets used in plastics more than wood. It's quicker than 3D printing!
As sailorman has said it is not easy, though it is easy to ruin a saw, particularly those with fine teeth.
If you have older, quality, handsaws with coarse teeth, that is the best place to start. Rip saws in particular have a simple tooth form and some have as few as 4 teeth per inch. Do it for your own satisfaction though, most people will just buy a thirty quid circular saw.
I have sent saws to a place near Poole who would even grind off an re-cut teeth but I can't locate them - they may have gone the same way as barrel makers. Mid Cornwall Saw Service will have a go at most things but labour is expensive. Even sharpening small circular saw blades is now uneconomic. In the c6in range I saw a box of three yesterday, TCT tipped, for under ten quid. It would cost over a tenner to have one sharpened.
