jiris
I will post a vid tomorrow, my idea of smooth, and a yachtsman's may well be very different things. I suppose in reality it is rarely if ever going to be at idle, and if we maintain our discipline about not using an engine it will be less of an issue - however I know we will end up using it just to get into the solent proper quicker, and to do so many other things rather than stare up at a slack sail praying for wind.
Besides of incorrect stiffness of the mounts, low idle revs, a bit of air in the fuel etc, the problem may be caused by improper distribution of the engine weight between the individual mounts. Yes, you do can achieve a correct alignment with the shaft by a variety of different combination of the weight resting on each mount. Ideally it should be the same on each of them - the simplest test is by a torque wrench on the adjusting nuts. I had this problem on my newly installed engine 2 years ago and managed to reduce vibrations by the above method to a negligible degree.
