First way of doing it proved the best one.Simple and robust with minimal moving parts.Easy to maintain and service.
Always somebody out there who thinks they can re-invent the wheel.First they invented a device that needed six extra bearings(count em),two UJs,two worm gears,loads of rubber pipe,two electric pumps and an instant corrode alloy case and called it an outdrive.Then to compound the sin,another bright spark takes away the hydraulic pumps adds a whole pile load of extra electronics and calls it IP??????? and denies your boat access to half the worlds moorings into the bargain. /forums/images/graemlins/grin.gif
Like you I have had both, and also like you I have returned to outdrives, however my reason for going back was because I prefer them all round.
On a sports cruiser they are much more fun when cruising. Far more economical, hence more range, and less queuing for fuel, but most importantly for me is I can handle them better in the marina. I could never get on with shafts, and would always dread the final few minutes of every trip (parking). Now much happier bunny, and if at the end of the day it costs me more overall it is worth every penny.
This is what you need to keep you busy for about three weekends freezing your n*ts off, breaking all your nails, and antifouling your head: two of these. Not bad for 2003's?
This costs thing is probably down to luck. In 4 years with outdrives I had the outdrive bellows replaced, oil checked and did all the cleaning etc myself and no real probs. In 4 years with shafts I have the barnacles removed for me each year (ok I'm lazy), one rope cutter break up (£400 the part) and cutlass bearings replaced (c£1500). I'm sure the outdrives get more expensive as they get older though. I suspect I've just had a bit of bad luck - just hope its now turned!
/forums/images/graemlins/frown.gif But I doubt I actually have the skill to get Catalyst looking that good! Best stick it straight in the water so none of you can see! /forums/images/graemlins/blush.gif
I went a bit crazy this year: just trying to con people that I've bought a new boat. Future efforts will be appropriate to the age of the boat: e.g. both drives infested with those shell worm thingies by this time next year, and no paint on any of the four props. Or if anything like the previous season, a variation on the patented 3&4 bladed duoprop system that involves one two-and-a-half bladed rear prop...
Must agree totally with oldgit on the cost issue. Having had both types - the maintenace costs on outdrives as the boat ages are many times higher than shafts. They get to be a real pain with some major work on them every winter. On my old fairline the legs cost more in maintenace than any other part of running the boat, and i include fuel and moorings in that equation. Unless it a new or nearly new boat - stay clear in my opinion. Now with shafts, and like somebody else in this thread has reported - nothing to be done at all so far.
