mjf
Need some advice please.
As many will know it was high springs at the w/e and certainly at Newtown Creek where I was we had a huge range. Then on the ebb on Saturday and again yesterday the current was roughly 4 knots.
During the first ebb I thought I heard a odd noise; on inspection I found both my shafts turning at roughly 60rpm! Never had this before anywhere, checked the speed log and this was showing zero knots.
So why are the shafts turning when they are actually quite tough to rotate manually and the paddle wheel log which is free to turn easily is not recording anything?
Next up - does this auto rotate issue cause any damage? I called Seastart to ask if it would be better to start the engines and put into gear before stopping them in gear and thus providing too much resistance to turn. They said leave it no problem for these to turn. I remember ages ago on here there was a debate about steaming around with one engine and recall it was felt that the idle shaft turning would cause some gearbox damage.
I recon when the auto rotate occurred on Sat I had 2ft under the keel, yesterday at strongest current I think as was lying in deeper water due wind direction it was 3/4ft clearance and rotation was very slow this time and was short lived too.
Be intersting to see what happens today as still on the same mooring.
