Poey50
A pinch fit is presumably when it's just held by virtue of being squeezed enough? I noticed the Yanmar on your website -- I have a Yanmar too (2GM20F with a Kanzaki KM2P), so perhaps I'm lucky in that regard. Or unlucky, as knowing this now I'll just worry that the shaft will fall off one day. Not sure about my particular coupling, will check tomorrow when I'm at the boat.
I have a split-halves Yanmar-type coupling. I have a particular screwdriver that is shallowly tapered along its length. With the bolts completely removed I tap the screwdriver into one of the splits. The shaft then slides out by hand. When refitting ensure you are using 8.8 high tensile bolts and torque them to the correct setting. I degrease and roughen the end of the shaft before fitting and also put my shaft anode 12 mm forward of the P-bracket as a final belt-and-braces.
