Shaft Seal for Recommendation
Fluter
New Member
23 Nov 2009
Sussex
Our ancient HMI Oil-fed shaft seal just failed and we need to replace it with something more current. We have a 27 footer with a Yanmar GM10 and folding prop. Shaft size to be checked but approx 1”. Any suggestions on what might work best as a replacement? Thank you.
I would reccomend the Volvo type stuffing box. All my boats have been fitted with them, none have ever dripped or failed.
You will need the tube size and the shaft size. I have successfuly epoxied a thin sleeve, turned from a bit of scaffold tube, to the outside of a GRP stern tube to bring it up to a size for which there was a Orbitrade unit available.
ASAP have a good range. Compared to alternatives, they are relitively inexpensive.
My PSS seal has also performed perfectly except on one long motor (14 hours the stainless steel rotor slipped back and allowed a leak which I only discovered after I arrived.
This I solved by fitting a clamp on coler like the one now supplied by PSS.
The stainless steel grub screws are too soft to bite into the shaft properly
Radice for preference. However your choice may be limited by the stern tube arrangement and size. 1GM is a very bouncy engine and can generate a lot of shaft movement and if properly aligned the Radice does a good job in dealing with this. my next choice if you can't fit a Radice to our stern tube is a Tides Marine which is also a lip seal but has a much wider range of choice of shaft and stern tube size. Make sure you measure your shaft accurately as the small difference between 25mm and 1" is critical.
I've just changed a 10-year old Volvo seal (nothing wrong with it, but the shaft was coming out to change the cutlass bearing, so thought I might as well do the seal at the same time). The replacement is an Orbitrade, not the venting one. It's a much stiffer rubber than the Volvo which makes it very difficult to burp - once I've got my arm in there I'm at full extent and don't have the strength to squeeze it hard enough. I didn't have this problem with the Volvo. So, if there is a next time, it will either be a vented one or another Volvo. The instructions with the Orbitrade refer to it as a 'Stuffy box'!
Our previous boat had an unvented Orbitrade. I had exactly your problem, hard to reach and then 'squeeze' to burp.
I found a gentle squeeze with a pair of water pump pliers was the answer.
On the current boat to make access easier I extended the seal 8 inches forward using an ASAP Exhaust joiner of the correct diameter and a new connector cuff and clips. It is now a doddle when it is annual lube time.
5 seasons on, over eight thousand NM's and nary a drip.
Both the original Volvo and the Radice are made by Radice. Orbitrade is a copy. Really no need to diverge from the original.
My PSS seal is well past the recommended bellows replacement date but still performs perfectly. It did once have a corrosion issue when laid up but since I began flushing with fresh water after haul-out this has not recurred.
+! best seal I've ever fitted.
What has failed? They're pretty simple, just a couple of lip seals with a header tank to keep the space between lubricated; new seals may be all you need for another decade+ of service.
My current Orbitrade has a vent tube-no need to 'burp'- and a lube port.
Far superior to a Volvo or Radice without those improvements.
IMHO, of course. From eleven years direct experience over two vessels.
