cagey
I want to move prop back about 20 mm. Shaft has 4 in R& D flexible coupling and 4 in split clamp coupling. Can any body suggest where to buy a spacer please. ASAP don't list one .
Thanks.
K
Thanks.
K
It's only a spacer. If you were in the Gobi Desert, you would just use a plywood or MDF disc. Why not?
Thanks for supplier, cor they're expensive might have a go at making one.
Unless you have the facilities, they are not as easy to make as they look. As stu says the registers and hole placements have to be exactly right and the finished item should be plated otherwise it is likely to go rusty.
The proper spacers have shaft and coupling registers to help with alignment
Stu
Suggest you get a quote for a one off from a machine shop which will put the price of a ready made one into perspective. Normally the only reason to fit a spacer is to make room for a rope cutter, so that is the only source of a ready made one.
Good luck if you have the facilities and skill to make one.
I made two large discs for a pot hauler, the problem is with the bolt holes, same as for a shaft spacer. As long as the registers are OK I would suggest oversize bolt holes, very difficult to drill accurately.
