Sextant Maintenance
Talbot
23 Aug 2003
Brighton, UK
I have an old sextant and am curious what you people use for the painted part of the sextant to keep it maintained (e.g. polish etc) Quite happy about the working parts, just the paintwork, as I suspect that the one I have got hold off may have been put away wit salt on it the last time it was used (a long while ago)
Sextant is a 1944 Husun.
robert_gainer
20 Aug 2004
I have a Freiberger, Cassens & Plath and a Husun sextant.
The C&P I wash in running water whenever I get the chance. It is a very robust instrument and I do not have any problem with it.
The Freiberger has a bad habit of getting a sticky index arm because the enclosed micrometer drum is had to keep free of salt and corrosion. You have to disassemble it to clean it. Only disassemble the back of the enclosed drum. I also wash it in fresh water when I can.
The Husun has a crinkle paint finish so you cannot clean it with anything that will not rinse off in water. If you wax or put polish on it you will live a film that attracts dirt. I would just wash it. But be careful of the index lighting on that one. It is old and prone to failure. Dry it carefully after you wash it.
I do not oil the underside of the arc or micrometer worm gear. I think that it attracts dirt that acts like sandpaper and wears the surface of the machined parts. I do not move the parts fast enough or far enough to need the lubrication. That is I must add contrary to the makers instructions. I have been doing this for 30 years now and my sextants are in fine shape.
