severe wintry weather
lyc
30 May 2001
Norfolk/Suffolk
Latest indications are that prolonged and severe wintry weather will become established during the middle of January.
http://www.theweatheroutlook.com/
This is the second long-range weather forecast with severe weather forecast for January,
Should I believe in the weather forecast and take the boat out sooner than planned?
chippie
21 Aug 2001
Northland New Zealand
Do you have any knowledge of the reliability of past long range forecasts?
I read a book on chaos theory that says long range forecasts are really only a best guess because the forecasters cant see the actual weather systems that will produce the weather, and weather itself is not a closed system .If it were a closed system it would constantly repeat itself which it obviously doesnt do.
On the other hand, some of the 'best guessers' are pretty good , so I am not much help at all,sorry.
Surely this depends on where your boat is and how sheltered is your mooring/berth.
Even in western Norway many yachtsmen leave their boats in the water all winter. Unless you are in an exposed location or in a harbour prone to icing, I would suggest you enjoy some winter sailing.
Sammy
26 Jun 2001
Its always bad in January. Depends on how sheltered your mooring is I tend to stay in all winter over the last few years and take a chance. I'm on a swinging bouy Portsmouth and seams to get less damage than some of the Marinas. Sailings good during most of the winter except January/ February.
Chris_Robb
15 Jun 2001
Haslemere/ Leros
If there is a period of very severe and penetrating cold - what happens to a boat were the laminate has a high water content or even a reasonable level. If it freezes within the laminate, this surely could cause major delamination.
On this basis, it could be better to leave a boat in the water.
