davidpbo
Bringing the boat back today one wheel got warm another quite hot. I had serviced the brakes and bearings last week. I had stopped to check the bearings etc. after 5 miles or so. I thought it might have been because the layby I had pulled into was downhill so the brakes wold have been on and decided to drive on. Stopped a couple of miles further and the situation was much the same, I backed the brake adjuster on one wheel off a bit and drove to some services where these wheels were still warmer than the others. As I was in a safe place I decided to jack up and investigate. The brake was still binding slightly so I backed the adjuster of a tad more.
The other wheel the inner bearing of which I had replaced last week had too much play in it. I can only assume that despite taking care the bearing outer had not been seated properly. Anyway, I tightened it by hand and there was no discernable play and I went on my way without further drama.
How do other people set tapered bearings? The Indespension Trailer Servicing guide used to say torque the hub nut to a fairly modest amount and back it off a 1/4 of a turn which is more or less what I did, so there was no discernable play but the nut was little more than finger tight.
