Sending me insane. AD31 DP-E
Either
1. Drive has been off and the potentiometer wheel that engages with the curved rack on top of the helmet has turned - needs to be reset (see the drive manual)if you have not buggered the pot.
2. Potentiometer is bust - bad news, its costly and vv difficult to get at.
This can happen. The shaft can separate from the toothed wheel. A replacement is available online from "Marine parts direct" based in Dublin, Ireland. Costs around €18.00.
Either
Either
If the potentiometer is knackered....about half the Volvo price.
Trim Sensor Kit for Volvo Penta 290, SP, DP, Repl: 22314183, 873531
you get to the sender (Part 22) inside the boat. I had the same issue. Removed the sender and moved the potentiometer manually but nothing happened on the gauge so bought a new one. Read the workshop manual on replacing as you have to line up little dots when replacing it.
if it’s the drive cog or rack....it’s an out of the water job
Be super carefully until it’s fixed. Where the drive thinks it’s down, you could trim the drive up into the “Beach” mode zone. Usually you have to hold down the red button but that safety feature won’t work currently. If you trim too high with the engine running.....bye bye UJ!
Probably the teeth were full of worm and the plastic rack has snapped or the wheel , it’s no big deal an easy fix
Either
Yes Thank you to all replies. Boat on the dry and both drives o/hauled , anti fouled and re-attached to the hull. The rack is intact and was correctly engaged to the wheel. Swopping the clocks has confirmed they are ok. Trying the stb. clock to the port elec. feed shows -9 and confirms it is a problem somewhere between clock and potentiometer. I have purchased a new pot. and connected to cable. Clock still reads -9 wherever I rotate the pot. drive. Connections checked with meter both ends and ok. Only thing I have not checked is for cable failure somewhere between pot and clock. Will do this today. Cheers.
Problem solved. What could be regarded as the obvious really, in retrospect. Three cables from pot to helm, the white/red one, no continuity. No idea how or where but chuffed to find the prob. Thanks for the interest and suggestions.
