Nautical
Looking at that picture Bart, you have an issue with the AP there for sure, shouldn't have any squirrelly line in the prop wash if AP set up right.
since Henry doesn't mind, I think we are simply talking about A/P gain control adjustment Bart. Had the same issue on my Cetrek a/p because the setup menu is so retarded and unintuitive that I accidentaly managed to max out the value on this. Result was much worse than what you describe, but trying to fix it I passed from this stage you're facing and eventually minimised it (and I'm talking D speeds since my one turbo was stuck...)
There's another complimentary value that has to be tuned as well, sure MM will come and correct me soon
V.
“Rudder hunting” that sounds like it; doing a straight course at flat sea, the boat is slightly going off-course, the a/p is giving a small correction to the rudder, it takes quite a while (wild guess, 2..3 sec) for the boat to react, then boat going the other direction off -course, again quite a while before reaction is noticeable,…
It seems that the reaction time between the command and the movement of the rudder is too long.
Hydraulics too slow? or "play" in the system ?
Do you have data for that mike or is it a guess? Most Nhavns don't, going by their website
..... I'm sure you agree that operating the rudders induces roll. The stabs react to that and correct it. .....
Thinking about it afterwards, the sea trial and testing the navigation stuff during the survey, didn’t get the same attention like the hull.Didn't GC highlight this in his survey? The excess of rudder hunting is too obvious to be missed. Or maybe you had some rough sea during the sea trial?
YES and YESWhen you say that it takes 2-3 seconds before the boat reacts to the A/P, you mean that:
1) you see either the port or stbd arrow appearing on the upper part of the display below (which shows the port arrow, in this case), AND
2) only after 2-3 seconds the boat steers in that direction?
It disappears![]()
what happens during those 2-3 seconds, does the arrow stay on, or does it disappear before the boat starts reacting?
That I don’t remember, that’s the part from the display which is difficult to readSecondly, while the arrow is on, you might see also a few LCD segments in the horizontal scale at the bottom, in the same direction where the boat is steering.
Did you notice if and how many of those segments appear, every time the a/p is operating?
I don’t remember as I don’t operate it like that,Oh, and did you notice, while steering manually, if on average the corrections vs. the neutral rudder position which you must introduce are more to port or to stbd (or neither)?
Don’t know, don’t look at a/p during manual steeringIn other words, when you keep a straight course manually (I assume you can! If not, pls specify), would you say that those LCD segments at the bottom appear more frequently on one side, or isn't there any obvious difference between port and stbd?
Anyway, we can definitely check a few things when we'll meet, even without moving the boat.
But at the moment, the thing which is more difficult to understand is the reason for the delayed reaction of the boat.
At P speed, 2-3 seconds are a helluva lot of time. Even considering that BA certainly isn't a light sportboat, she should react much faster than that.
It's simply impossible that it takes her so long to steer after the rudders are actually moved.
Therefore, you might be correct in thinking that the problem is elsewhere - e.g. a weak pump, or whatever.
In which case there's no calibration on earth which can improve the performance of the poor A/P, of course.
And that's one thing which is difficult to check without moving the boat, because unless there's a delay in the rudders movements even without any pressure on them (which would be the worst case, but at least useful for troubleshooting), it's necessary to check the rudders operation while cruising at speed, in order to understand what's what.
Interesting problem, anyway.
It's surprising to hear that the previous owner didn't seem to bother too much about it.
I am lazy enough to leave happily with my grey teak (sorry jfm), but I'd go nuts for a thing like that.
Your pic alone is enough to make me nervous...!
Ok, unfortunately that is the most critical point of the troubleshooting, so I think we must postpone any further evaluation to when we'll meet.That I don’t remember, that’s the part from the display which is difficult to readDid you notice if and how many of those segments appear, every time the a/p is operating?
Naaah, why should we?long shot, so don't shoot me...
the delay in response MIGHT be that there's air in the circuit that compresses and the instruction IS given
is there any loose joints in the steering mechanism. posh word for something loose.
The boat is pretty heavy, hence inherently stable (she also has a keel, IIRC?), and the rudders might be a bit small.
Whoops. God knows why I thought BA had one.no keel MapisM !
In the good old days, keels were not so unusual also on P hulls.
