self tailing 'adaptors'
neil1967
28 Nov 2007
Tavira, Portugal
self tailing \'adaptors\'
Hi
I have previously seen adverts for a plastic ring that fits around the top of a winch to make it a self tailing winch. Does anyone have any experience of these - seems a bit too good to be true?
jerryat
20 Mar 2004
Nr Plymouth
Re: self tailing \'adaptors\'
i have 2 on halliard winches. they do work
Oh dear, I tried the things, 'Winchers' I believe, many years ago, but unless they have been dramatically improved in the interim, they'll still be a complete wate of time IMO!! Not cheap either! /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif
alldownwind
10 Aug 2004
Medway
Yes they do work (rubber, not plastic) but they do not fully replicate the action of a s-t winch - you still have to peel the rope tail off, difference is that you don't have to keep the tension on it.
They are now badged and marketed by Barton Marine.
sailorman
21 May 2003
Here or thertemp ashore
if the drum is full of turns tight up under the rubber, thats all thats needed. the top groove in the rubber is only for belaying the sheet NOT self-tailing it.
they dont opperate the same or replicate S.T winches
Alfie168
28 May 2007
It all depends on what you expect of Barton Winchers. They do improve a conventional non ST winch, particularly if you are sailing short handed, but its going some to compare them to a full self tailer...but then for £40 or so, what do you expect.
I have used them and certainly found them useful rather than useless, and on balance I'd definitely rather have them than not have them, if that were the only choice.
Tim
cnh
18 Oct 2003
I had them on a previous boat, and they were excellent.
Nicholas Hill
Alfie168
28 May 2007
There are three sizes of Barton Wincher. The smallest Lewmar winch suitable for them is the Lewmar 8. Anything above that and there should be one to fit, as the wincher is a stretch fit (a bloody difficult stretch fit I have to say)
Tim
allanc
4 Aug 2001
hampshire
Yes, they do work and are good value. They do self-tail by putting on four or five or so turns to fill the drum up to the underside of the 'wincher'. When you've winched in just cleat the rope into the jammer groove. Easy to use and nothing to break. Once used, you'll always use them.
noby
23 Jan 2007
Dungarvan, Ireland.
Good to see some positive feedback on these. I bookmarked these for my 'to do' list over Christmas. As I recall. there was a US site selling them for a lot less than £40.
FrancisRutter
23 Jun 2004
Norwich
I had a pair of winchers [suspect I have thrown them away now]. Simply could not persuade them to go onto the winch although they were supposed to be the correct size. So have no knowledge of them in use.
damo
22 Feb 2005
k keeper,Portishead
longkeel35.org.uk
Noooo! What a waste /forums/images/graemlins/frown.gif There is a knack to fitting them, which has been posted several times on the forum in the past.
I'd still rather have s/t winches though
Leighb
8 Aug 2007
Suffolk
I have fitted to them to a pair of Lewmar 30s, would love some new Lewmar STs but have spent a lot already on other "essentials".
I was prepared to be disappointed although a friend had said they were good.
However they are pretty effective at the price. You do need to put plenty of turns on so that the rope is gripped under the wincher itself, and it does self tail.
I think the main disadvantage is that it is much more awkward to release the load when you need to tack or trim.
Other than that am well pleased and will use them until the budget allows for the new STs.
doug748
1 Oct 2002
UK. South West.
Might think about this update, not for the self tailing action ( which I consider a little overated anyway ) but to prevent damage to my shins, from the top of the winch, as I clamber back into the cockpit at sea.
ridgy
26 Jan 2003
North West
I have an unused medium pair that are too big for my winches if you're interested. Say 50% of rrp + postage.
Or swap for small if anyone has some.
