anoccasionalyachtsman
There are two types of curved track systems that I know of, one where the sheet comes along the side deck, up onto the track end, through a block on a car, on through a block on the sail, back down to another block on the car and on to the other end of the track, where it's made off or led back to the cockpit again so that there's a sheet on each side. The other has the sheet led from the cockpit, into and up the mast and out at about first spreader height, down to the car and up to the sail (or double up for purchase). I think David Thomas came up with it for UK Hunter. The former loks the best, but suffers from friction from the fact that the sheet run through the three blocks. The latter looks a bit odd, but has way less friction, only the car itself adds any. Disadvantage of both is that the sail twists off as soon as it's eased, so you need conventional sheets on it for reaching if you're bothered.
This is the long batten I mentioned, and I thought it was a Freedom Yachts thing, but I've subsequently seen much older drawings of it. They all seem to feature the odd kink in the luff, which I don't like and would chat to a sailmaker about how we could avoid it with more reinforcement. (Obviously point loading the forestay isn't a good plan). This is the route I'd go down.
