Self draining toilet
Jelly
5 Jan 2004
Essex, Crouch.
Why does my toilet always self drain? I have the valve set to discharge directly into the sea, and the valve itself is located higher than the toilet base. Its a leccy toilet, but I dont think that makes any difference?
Thanks.
PaulF
20 Feb 2004
Chandlers Ford, Hants
Worrying in this area may cause it to reverse, THEN you will have need for concern. IMHO the quicker it dissapears the better. If you do want to retain it however, shut the seacock!
miket
21 Jun 2001
N Hampshire
Me too!
Both my last boat and current boat do same. Both electric loos, but current one goes direct to holding tank with h/t pumping overboard with manual pump.
Doesn't seem to happen but wouldn't I get smells from holding tank coming up loo if no water trap?
Perhaps water trap there but lurking just out of sight?!
HeadMistress
9 Sep 2003
USA
Re: Me too!
Nope...marine toilets don't need water traps. They're fitted with a one way valve called a joker valve instead....which, btw, should be replaced at least every two years.
In fact, a water trap would actually cause odor instead of preventing it, because sea water stinks something awful when it's allowed to sit and stagnate in summer heat between weekends aboard.
<hr width=100% size=1>Peggie Hall
Specializing in marine sanitation since 1987
