Seven Spades
I am looking for a technical drawing of a See-Me radar enhancer. Mine is mounted on a quadrant at the top of the mast. The aerial is about two feet long and all that holds it is a flange through which the cable passes. The See-Me has a plastic thread about 18mm and 50mm long which is screwed into the flange. However the threaded section has snapped so now the see-me is gaffer taped horizontally at the top of the mast. I cannot glue it back together as there is not enough material and the forces of the boat and a 24m mast would be too much, that is why it snapped in the first place.
I need to design a clamp to secure it vertically but I really need a drawing otherwise I will have to go back up the mast with a set of callipers…I cannot easily remove it because the cable passes from the see-me straight down the mast and trying to find a white cable at the bottom…and I have no confidence that I would ever be able to re-thread it should I pull it all out.
My idea is to make a wooden block in two halves that I can screw together that will encompass the base and part of the quadrant. I assume that it will not detract from the signal if it grips the bottom 2 inches of the tube.
