vyv_cox
Hi Vyv,
The prop has a boss which bolts onto the shaft. The shaft and retaining system butt up against this boss.
The boss has a resilient rubber bush which drives the prop hub. This electrically insulates the hub, hence blades, from the boss and shaft.
Best option is to look at the Boat Show. They are keen to talk about the products.
I suspect the boss and hub have some sort of drive spline system to carry the substantial torque loads involved. I imaging the, should the rubber be eroded, there would be metal to metal between the hub and boss.
As soon as I'm back, I'll look for drawings.
It is an amazing piece of kit from an engineering point of view.
Tony
The Autoprop website shows none of this, neither does the video, although all are specifically for saildrive units. They say the rubber is for shock absorption, not insulation.
