vas
What do Garmin do for ethernet plugs? RJ45 or do they have something proprietary and water-resistant? Raymarine have a proprietary round connector which I prefer over RJ45 on the radar and the plotter on deck, but if I need to add anything else to the network in future I will cut the cable between them (there's a loop of it run through the back of the chart table for the purpose) and fit RJ45s and a third-party semi-rugged switch. I've already fitted RJ45s in a waterproof coupler above the headlining for the mast joint.
a simple RJ45 on a proprietary water resistant cover, that bolts and seals on the radar and plotter side.
for sure a simple RJ45 cable works as I've used it inside to connect the sounder to the plotter (1m appart on lower helm, no need for waterproofing!)
having messed about with NMEA0183, I'm VERY happy I don't need any.
but I do have 0183 to two GMIs! The 0183 signal is produced by my arduino teensy /due black box to simulate autoanchor signal and use it as a chain counter. Definitely cheaper than the grand these black boxes cost...
My problem with Garmin is that they are not happy/don't bother support NMEA2K sentences that their own kit doesn't produce.
IE, don't have EGT sensors, so 4,5,6K series plotters dont support that!
John, can you show EGT on the 8000 glass bridge kit, or you use a Maretron display for that?
cheers
V.
