Seastart
wombat88
1 Oct 2014
I'm thinking about signing up to Seastart for a small motor boat with a 50hp outboard in which, despite everything, I have no confidence.
I've looked at their website and all looks good but I am keen to hear from people who have had to use their services.
Anyone got any experiences good or bad?
Used them twice. Once they turned up quickly fixed the issue promptly, clean tidy, nice guy. ( Boat was in a marina on the Hamble which may have aided speed.) Second was for an issue i wasn't sure they could fix ( dodgy windlass - Boat was moored up and just tested it before setting off) - They couldn't but knew a man who could. I used him and he was fine - turned up quickly, fixed the issue etc etc.
I have just renewed my membership with them which tells you something. To me, if you'd pay for AA for the car then SeaStart seems a sensible use of a small amount of money if you're mainly cruising in their area of operations
I joined when we bought a new (to us) boat with an engine I was new to looking after. Then, for the first time in my life, I picked up a rope round the prop. Sea Start arranged a diver which cost me £50. They were helpful, friendly and quick to respond. I would recommend them if you have an engine that is a bit of an unknown quantity and you are in an area they cover.
I'm not a member but know someone who is and they had to use them twice I believe, in 2 years, due to various mechanical breakdowns. He was impressed with the service. Do make sure that you are in their area as they aren't round all the UK yet.
I've been a member for must be 20years+ and in that time I think I've had four call outs, one where my drives belts all failed due to a bracket bolt failing, they got me up running so I could limp home within an hour, the second was fouling a floating lobster pot rope, they came over with a diver(no extra charge), took the props off and refitted, again within an hour, and the third was when a relay failed on the drive trim, that one they arranged a local engineer to fault find and fix as I managed to limp into marina. The other call out was at my home berth, faulty oil pressure reading, they confirmed it wasn't an engine issue.
The other thing I like is you can call them any time for advice regarding the engine. Their service is simply excellent and a no brainer considering the low cost membership. Most of my issues couldn't be identified during my normal maintenance checks, hence why I stay a member. The extra cost is parts which seem reasonable given the circumstances or they can use your spares if carried onboard.
I'm a member and have had two call-outs. I agree with previous posters - 1st rate service, excellent value. Check that they cover your area - they don't have boats in all UK waters.
I have been a member for 3 years and had 2 call outs one just after launching starter motor failure and another time when the engine would not turn over after returning from a trip . Both times the engineer was there in 30 mins . Fixed both times with the spares he had and even followed me back to my mooring . Very good service .
I have been a member for about as long as they have existed. I have called them out only twice, but both times it was a major problem that couldn't be resolved at sea and required a tow. I renew every year for peace of mind, even though I have the knowledge to fix minor problems and plenty back-up systems on board. There's always something, sooner or taker, that will get you, even just a bit of stray netting round the prop!
Any experience of using Seastart is generally bad - but that is why you joined and then called them out !
Highly recommended, and run by a genuinely nice, real and lifelong boater - Nick Eales.
Two primary reasons: 1 Bad fuel; 2 Bad electrics - and I understand in no particular order.
it's a bit of a no-brainer I think, £155 a year for a call out service. Never had to use them, yet, but it's peace of mind if something does go wrong. Those I know who have used them them have always been happy with the service
Good heavens, going to sea on a mindset that someone else will get you out of trouble, is a bad and unseaman/person like basis in the handling and maintenance of a yacht.
... probably sailing without the skill of sewing is also OK.
I am an amateur and not in the yachting industry, but I am very aware of my responsibilities to myself and others
Unfortunately there was nobody to help when we were battered by F11 mid Atlantic, but we survived. Now approaching 80, I don’t fancy going over the side to clear a rope from the prop these days, so Sea Start is a must for me. Presumably you shun the RAC, AAor Green Flag too?
It's not really a mindset that someone will get you out of trouble, nor associated with a lack of maintenance, but more of a peace of mind that if something untoward and out of your control happens, you have a back up / support plan.
Personally I'd call that responsible seamanship.
Be aware that their area of operations is quite restricted, basically South Coast only, and not even half of that. Area of Operation | Sea Start
Yes, you need to look
Indeed, and they only operate up to three miles offshore - mind, we only operate Weymouth to Chichester these days and mainly the Solent - with a Mobo to boot with bloody VP engines!!
On that basis we'll disband the RNLI as well then?
If I go sailing in our 12' dinghy I have sails, oars and even rowlocks. I know how these things work and intend to be self sufficient.
If I go out in our little motor boat I am relying 100% on a 25 year old (maybe) outboard that has fuel injection etc etc and has obviously not been looked after until my ownership. I do not know the detail of how it works. Even if I were to learn the fault codes and had bought a dongle to give a read out on a laptop I doubt I would know how to remedy things without replacement parts.
