rajjes
I’m replacing a thru-hull and am planning to use sikaflex as sealer.
I understand that rather than tightening it up fully immediately, it would be better to tighten it gently, leave the sealer to set and then tighten further.
Could you confirm that this is so? Also, should I use the sealer only on the outside and some of the lower threads, or also under the securing nut? (If so would it set too hard to allow further tightening?)
Apologies for these basic questions but I guess its better to double check as its below the water line!
