Petercatterall
I had a drip from the impellor cover on my Perkins 4108. ( unlike an earlier post I can access it with ease)
I had replaced the impellor after winter lay up and used no seal as there was not one on before.
Is there a seal for these punps? just a paper one I guess. I considered using nonsetting gasket goo but am concerned that this will squeeze inward and foul the impellor.
I notice that although the impellor is pushed well on the rubber extends perhaps 0.5mm beyond the pump flange, this may be taken care of by the slight recess which is machined in the cover plate. Does this seem reasonable (apart from said leak it all worked OK with no apparent damage to the impellor.
Any advice welcome.
I would like to get hold of a set of screws for the pump as the orginals are a bit dodgy I cant locate the right size locally, can they be ordered?
Are the kits which enable you to remove the cover by hand any use?
I did drill a hole in the bulkhead to help access to the screw head.
Thanks... in anticipation of the usual helpfull response!!
Any advice welcome.
