Mike W
New Member
We’ve had our lovely Sealine S34 for just one year and have discovered , what appears to be, a substantial leak into the aft cabin. The carpet covering the “lower” floor area between the two bunks became very wet towards the starboard side. When I pulled up the carpet and the wooden boards under it I found everything was horribly black with mould and soaking wet. The water appears to be coming from under the rear bed and over spilling into the bilge. I scooped out about 20 litres. I’ve now done this about 3 times. It is fresh water. The water pump does occasionally activate when we’ve not used any taps which lead me to think it must be leak In the fresh pipe system somewhere, possibly from the tank itself as is sits at the same level as the floor area in the cabin.
I did read that the catwalk drains when blocked can flow into this area (which does seem very strange) but these seem to be free flowing when I checked them.
Has anyone had any experience of this? Does anyone know which pipes are in this area. The constitution under the bunks looks like a “tub” with two individual bunks screwed down on top of the tub. A schematic diagram of the area with the associated pipe work would be really helpful.
Any help of advice would be much appreciated. Many thanks
