Sealine F33 electrical issue
Georgecdrummond
New Member
4 Jan 2018
I recently bought a 99 F33 but I’m having issues with the starboard electrical controls I.e. no trim tab, engine leg, battery charging to starboard batteries. Is there a common relay or fuse that would cause this to happen?
I have replaced the batteries, by passed the wiring to the leg pump and the motor runs fine, up and down.
Any help would be appreciated.
George
The is a large nylon fuse on the top of the engine I believe - It is about 3cm long and 1cm wide with studs on.
If this goes it does as i recall stop the leg and trim tabs working - but it would have nothing to do with charging.
George
Are we talking Volvopenta or mercruiser ?
Volvo then could be the pop fuse inside the black box top of engine, I’m assuming it’s a Kad 32.
Can you hear the trim relays clicking , they will work even if the main power supply trim pump fuse has blown , this is located on top of the engine inlet manifold , thick red cable from starter motor .
No charge sounds like alternator fault as ther is no split charge system on an F33.
You say trim tab , do you actually mean tab or trim function the drive leg?
Paul, The boat has twin Kad32’s and yes I can hear the relay click on the leg trim so it sounds like the fuse has blown do I find it in the black box on top of the engine or on the starter motor cable? Is the same fuse responsibile for supplying power to both the engine leg trim and the trim tab?
Top of engine fuse is cream colour with 2 8mm studs .
Trim tabs nothing to do with engine . Sealine fitted unfit for purpose elltrim shyte tabs . Rams fill up with water .
Water leakage is mainly down to not changing gaiters every two years, plus cheap German engineering, fuse / circuit breaker with bilge pump, charge circuit, heating breaker panel.
Brian
Paul,
I found the fuse but it was situated right next to the starter motor ( within 5mm of the starter connections?)
I have tested across the fuse and it was still intact so I guess my search continues.
George
Paul,
George
Does your trim gauge show -5 or -6 ?
There are 2 relays on trim pump and connectors to check .
There are 3 relays associated with trim function behind lower dashhelm check these .
If you have no readout the trim can’t function as it doesn’t know the leg position.
Try to raise the drive by pressing the overrides button
The gauge reads -1 at the moment and I have the overrides but nothing , I was going to try opening up the switches and swapping them with the port side switches as I know they work fine to see if they are at fault if not then I will remove the large fuse from the circuit for a quick test
If the other side works then I’d be swapping the trim buttons over to test them there prone to failing .
