dj43
Hi all need some advice on what sealant to use to re bed external joints between hull sections, needs to be black in colour,
Found a small leak coming through the joint on the hull flange that bolts the flybridge to the hull sections, think the cause is where the flange has been drilled to pass electrical cabling through , reducing the surface joint area from approx 50mm to 10mm , going to dig out the old sealant as far as possible and inject the joint with new sealant , there are so many different types on the market not sure which one is best suited .
