Kinsale373
I've suceeded in pumping out my Diesel Tank and removing and cleaning it on my Bene 373. I was surprised at how clean the tank was for a 2004 boat. Just a cup full of Black Gunge at the end of the tank. It was so clean that I decide not to steam or power clean and instead rinced the tank well with clean diesel.
I used a RACOR Fuel Filter /water seperator Funnel to filter all my diesel and and it works well . I set it up with a small syphon (6 mil dia) from the "dirty can" feeing down to the Clean drum. and over 15 Mins filtered 20 Liters at a time. works well but keep an eye out for filter blockage or you'll have diesel all over the floor,
So once the storms goes through on Moday the tank does back in next week !
Question s: I noticed that when removing the threaded screws that hold the 2" Diameter plates to the top of the tank ( Used for entrance of Fuel pump and return pipes , Depth gauge and heater pipes. ) that the screws had some type of purple colored sealing material on each , like you would do with a screw through fibre glass. Has anyone a suggestion on what would be a good material to use to reseal the screws in the tank and maybe use a s a gasket meaterial beneath the plates ?
I'm wondering if I I should use the same material to get a good seal on the 2" Diesel filling pipe that goes onto a spigot at the rear of the tank? Or are the double Pipe Clips good enough ?. It as a wrestling match to get this connection off anyway? Still I dont want any diesel leaks .
Interested in your thoughts, Kinsale 373
