tonkatoy87uk
Good evening,
Just finished coating the bottom with hempels hp2 2 pack epoxy.
We were originally expecting to put seajet 015 single pack primer on when tacky
then seajet 37 coastal hard antifoul
Untill today i wasnt aware of the correct hempel "process"
Hempel book says there single pack (light) can be put on when the epoxy tacky - missed the boat for this now
or
2pack underwater primer if the epoxy is past tackly and gone past its recoat time.
Neither of which i had -
just painted a fresh coat of epoxy expecint to use seajet 015 on the tacky hempel
just as I was about to crack the 015 tin a fellow boater said it might be an idea to check if they would take to each other when tacky being resin based.
So
I should have checked this before hand. - but didnt.
ive now got drying hempel epoxy - now well past tacky
Do I let the hempel hp2 dry completely
and use seajet 015?
Is this do able?
does the epoxy need to be keyed up before the seajet primer?
Or pay out again for hempels 2 pack under water primer and then use seajet 37
New to it all
Speak to 10 people get 20 conflicting answers.
or
So
and use seajet 015?
Is this do able?
New to it all
