mackerel man
Would a 5hp seagull outboard be powerful enough for a Shetland 535 to use on sea for inshore fishing and be safe any advicce
Just about provided you don't want to go far or other than fairly slowly and dont mind the noise.
You would have to be very aware of the strength of tidal streams
I assume you are looking at an Osprey model ? http://britishseagullparts.com/seagull-5-osprey.htm
Or an anchor.
Short ( aka standard ) shaft model is I believe correct for a Shetland 535
You might want to fit a long range fuel tank as refuelling at sea is a pita
I think you will very soon want to replace it with something more powerful. The 535 will take up to 55hp The Seagull would still came in handy for trolling or as a back up
Agree with the above: Their 5hp was in reality 3-4 on a good day! Whichever, its not enough to push a Shetland reliably .
Yes sure, it will push you at 3 - 4kts in calm water on a fine day, but as soon as the wind and sea get up you will be floundering around making little or no headway. Bad enough having to spend a lot of time getting to your fishing grounds. Worse still when you find you are struggling to get back again at half a knot if you are lucky!
Character They certainly have plenty!But just about every other make beats them except for character, for which read noise, smoke, unreliable starting, oil all over everything, and in a trail across the water.
