VicS
With a multimeter - how?
on the lowest ohms range or using the continuity buzzer if it has one. You might need a long lead/leads though to reach from the anode to an exposed metal part
Not sure but will check when I am down there tomorrow. Is there anything that indicates that the seacock and through hull fittings should be replaced?
Vic - thanks. You are dealing with a rank (but keen to learn) amatuer here, so given that my voltmeter does have a continuity tester, do I wrap the exposed end of a long lead around the pushpit, then have the red probe on the anode and the black probe on the other end of the lead that is attached to the metal on the pushpit? Never done continuity testing as you can tell, I use the voltmeter in it basic form so I assume one of the probes (black?) needs to be moved the to the COM port (?) on the voltmeter? Is a buzz good or bad?
