rhino_mac
Sorry if this seems blindingly obvious. Only owned my boat for a few weeks and trying desperately to learn everything I can about it.
I've heard a lot of issues with boats taking on water and sinking, something I'd like to avoid if possible!!!
What is a Seacock? And what are the issues with them? I have a Monterey 250 mobo. Do I have them? Can I inadvertently "open" them?
Such a dumb question I'm sure, but on the basis I only realised the other day the reason my toilet wouldn't flush was because it was on dry berth and needed sea water to fill up (the dangers of taking manuals on board to try to work out how stuff works), I don't want to do something by accident that sinks the boat.
And on that matter, plugs. Someone at the marina suggested I take mine out from time to time. I guess rainwater might collect in the bilges. Am I right in thinking the plug is the metal "screw" for want of a better description below the leg that has a 10mm (ish) square "nut" on, held into the hull with four screws. Do,I just remove it with a spanner and allow any water to drain out, then refit? Does it need sealing with any special sealant or will screwing it in suffice?
Thanks for your help. Sorry if this seems obvious!
