KMM
I have a Seamaster 925 on which the outlet from the head has totally seized and no amount of force, heat, plusgas etc seems to work.
Can anyone help with either suggestions to free off, or help identify the fitting if I have to purchase a replacement? It is a bronze casting, being one piece skin fitting and valve, attached to the hull by a 4" square flange with outer plate and four through bolts. There is a top cover secured by three bolts through which the shaft emerges vertically, and under which there is rope packing as in a stern gland. The inlet from the head is to the side of the body.
There is no room to replace with the common off the shelf fittings available in local chandlers.
