Murv
Great, thanks for the help
Either in this thread, or elsewhere I have suggested any easy to make tool: find a socket from an old socket set that would fit if the lugs were not there, then cut a groove down each side.The fitting should have kind of two "dents" (have no word here) on inside, there is even a special tool but something else can be used to engage on them. Second person from outside to hold it still is good idea.
Dive in the water plug the hole and service the cockseacock!!
If he dives in the water he'll have difficulty finding the hole - the boat is up on bricks in the yard
Just use an angle grinder.(cutting a socket down will be difficult for me)
I used a piece of mild steel flat bar & bent the end at right angles in the metal boat stand & got someone to hold it
Thanks for that
I don't have one. Obviously I could just get a cheap one, but if it costs more than a "proper" tool to fit then it may not be just worth doing that.
May get one anyway though, I guess it will be worthwhile around the boat
Really? You sounded reasonably well-equipped and competent in another post
I just drilled a hole through the socket (crappy old market-stall one) and then sawed down from the end to the hole with an ordinary hacksaw.
The "proper" tool is called a step wrench.
"Step" i guess because it is stepped to fit various sizes of fitting,
Thanks for that, much appreciated.
I did try to find a bit that fitted a 1/2" drive ratchet but it appears that they only fit a plumbers wrench, whatever that might be which racks the cost up.
So, I'm going to have a go at PRV's idea. I have a vice and an old pillar drill (both unused so far) so it should be do-able![]()
You can get some that you can hold with a n adjustable spanner .
For a one off job it's still not worth it , A piece of flat bar the same width as the bore of the fitting will do.
All assumes of course that there are little lugs inside which will engage with any of the "tools"
Internal pipe wrenches exist too which will grip the inside of a smooth fitting.
Ok, thanks, first thing to check then is whether or not it has the lugs. If so, I'll knock something up, if not, off to a plumbing shop for something suitable.
I am intending to refit the old through-hull fitting after it's been cleaned up (assuming I don't need to damage it to remove it,) any reason that I shouldn't do that?
. . . . The parallel threads are jointed with Locktite 275. A contributor on the other thread used Locktite 577. Again, anyone care to comment on the difference?
