Seacock Location Princess 50 MK1 Cruiseair System
aisltd
14 Nov 2022
Evening can any one help?
would any body know where the seacock is for air con on princess 50 the compressors are under the galley floor also the pump and strainer the pipe for the sea cock disappears under the floor have searched everywhere any one know? I have the dreaded Low pressure
so would like to clean through pipework and check strainer hoping its a sea water flow problem a bit worried about removing pipes etc without closing seacock
IDut
23 Nov 2021
On my Mk2 the seawater pump is in the rear of the engine room under the rear wooden cover at the bottom of the steps. The seacock is under the mist panel at the front of the lazaretto
burgundyben
28 Nov 2002
Niton Radio
Surely you must be able to see or feel where the hose goes and then go looking in the adjacent bilge?
Ita a bit worrying you've got a skin fitting you dont know the location of. I'd have thought all skippers need to know the location of all seacocks?
Moonstruck
28 Sep 2020
Agreed but not always as easy as you say. On a survey I had last year the surveyor could not locate two seacocks . Only by a process of elimination when the boat was lifted could we find the area to look. The seacocks had been installed in the boat and then a panel glassed in and the generator and air con installed on top. Completely inaccessible and done from new.
aisltd
14 Nov 2022
Thanks for all your reply, we have the princess original manual and it shows below the galley floor but you can't get at it as its behind water tanks, we have now found it , its in the mid cabin down in the corner
side of the bed there's a small hatch for anyone who's looking for it also.
jrudge
4 Dec 2005
Live London, boat Mallorca
Given you need to get to seacocks quickly it if all goes wrong the design does not seem to clever.
mine are all in the engine room other than the heads which are under the master cabin floor via a large hatch.
I am honestly surprised they have made them so hard to find.
aisltd
14 Nov 2022
ThanksAll
Have now found it under small hatch on starboad side of bed mid cabin,
Have a air con question for princess 50 MK1 is there a air handler in flybridge sealed hatch ajacent helm seat That blows
air out of ceiling vents lower helm ?
