jhr
After months of prevarication, procrastination and dithering, it looks as if I may, finally, be on the verge of buying a boat.
The survey and sea trial is tomorrow and, although I have my own checklist of things to look out for, I'd like to hear what others have looked for when conducting a sea trial. The survey will obviously cover structural matters.
Without descending into List Hell, mine broadly comprises the following:
Hull and superstructure: Does anything leak? Any evident list, or oddity in ride, whether at low speed or planing? Does she handle OK (ideally in a chop, tho' the Solent may not be helpful tomorrow)? Are all the deck fittings etc. in good order and doing their job?
Mechanical: Does the engine start/go/stop OK? Are the instrument readings OK(if the clocks are working!)? Does anything go or feel wrong at sustained cruising speeds? Does she perform according to manufacturer's spec (she's only 2 years old and will be scrubbed tomorrow)? Does anything go wrong at WOT? Any signs of faltering/hunting/etc? Any evidence of prop or leg problems (vibration etc) or general wonkiness? Does she engulf petrol, or merely slurp it in large gulps? Does the leg go up and down?
Electrical: Does all the kit work? What sort of shape's the battery in and how much does starting up take out of it? Is the alternator working? Any evidence of gremlins, contact problems etc generally? Do the water system/blower/bilge pump etc. work?
Anything else? All suggestions gratefully received.
Oh - nearly forgot. The boat's a Sea Ray 215. Merc 5.0L petrol.
TIA.
<hr width=100% size=1>
TIA.
