gravygraham
Apart from the obvious, have you peeps got any tips of things to look out for.
Its an engineer you need on a sea trial more than a surveyor, in my experience most surveyors dont cover the mechanical/ engine side of a survey.
And preferably an engineer that specialises in the make of engines your intending to buy.
Apart from the engines/drives, have a very close look at the steering rams and power steering system and fluid. There have been a number of threads on here on VP power steering issues, with the rams sitting in the water, and subsequent marine growth causing seal failure on the rams.
Ask for service receipts for the mechanical bits, and check against the service schedule. It is what you can't check for and don't know about that could come back to bite.
See how the engines start from cold. Ask them not to start the engines until you arrive. Feel the blocks to ensure they are cold before starting. If they start well from cold that is a good initial pointer.
Sorry guys but these are modern direct injection diesel engines. They have NO choice, they have to start, engine turns over, when sensors report all present and correct ECU signal injector solenoids and engine fires straight up.
In this temperature motors will sound 'harsh' as they have a 3D timing table and ECU is advancing the heck out of the timing to cut out start up white smoke. In slightly warmer ambients combustion noise is less aggressive as ECU is not whacking in such a big slug of timing advance.
All that should have been checked by an engineer while the boats out of the water, no good doing it today when its in the drink, if hed have told us the boats name etc maybe someone might have some history of it, me included to pass on.
Probably one of the loudest engines on start up is a CATC15 engine, the advance is horrendous for about 90 seconds, then its a sweet motor.
D4 is a modern motor and will start as long as there is a decent voltage supply and of course fuel.
