Scillypete
Planning on fitting some mast steps this winter, standard alloy mast, stainless steel steps, which will be best to secure them with, stainless self tappers or monel rivets?
The self tappers will leave a lot of sharp points poking into the interior of the mast. They might shred your halyards. A bit more trouble to do, but I'd prefer the monel rivets. Check, though, that your riveter can get to all the holes in the steps.
It is veery easy to tap a thread into the ali mast. Just buy the correct taper tap and screws. A battery drill with reverse can drive the tap in very quickly and easily with easy reverse. If you choose to use rivets you will need a powerful rivet puller. You might even consider buying or renting a pneumatic riveter. I have one and it is magic. olewill
Lots of people suggesting monel rivets. I am not sure why there is any necessity...
Fair enough but note that the data in the link has reservations about the corrosion of copper- nickel rivets in aluminium in marine environments. The strength of 5000 series aluminium rivets is well above what is needed.When I'm up my mast, I'm perfectly happy that my steps are attached strongly and securely, and couldn't care less if they are "over specified".![]()
Lots of people suggesting monel rivets. I am not sure why there is any necessity. It may not generally be known that pop rivets are produced in two principal grades, 1000 series, which is unalloyed, about 99% pure aluminium, and 5000 series, which is the marine grade. Professionals will use the 5000 series ones for mast work, where the mast will be anodic to the rivets, thus protecting the rivets themselves. These are widely available from many suppliers and will be perfectly adequate for this job. Monel rivets have their place where greater strength is required but their additional corrosion resistance is unjustified in most applications.
Vyv, that is really useful. I can't find anything about the 5000 series rivets for a job myself (of metal cleats to alu mast). What are the 5000 series ones made of please - and is there another name used?
