eebygum
Thanks in part to expert advice from this forum we had a lovely sail from Lytham-St-Annes down to the Menai Straits on Saturday which took about 10 hours under sail and then motar-sailing...... however at various points in the trip the Yanmar definately got a bit moody !
The engine would purr along nicely for anything up to 2 hours put then periodically for up to 2-3 minutes shake violently on the engine mounts and make a right racket ! only to disappear as quickly as it appeared. It lasted probaly about 10 mins in total for the whole duration of the trip.
It did not appear to be dependant on the tack, the load on the engine or the state of the swell or angle of heel and continued even when the revs were cut back.
Any suggestions on what could cause such an intermittent problem, if there was a problem with the engine mounts then surely it would shake and rattle vioelently all the time ?
If the engine mounts had to be changed as a precaution can this be done when the boat is in the water ?
Thanks in advance.
Age is a question of mind over matter. If you don't mind, it doesn't matter.
Thanks in advance.
