skyflyer
Last winter I installed new plastic sanitation 38mm hose throughout the heads system, which essentially goes from the heads to a diverter valve to send waste overboard or to a holding tank.
The previous pipework (heavy rubberised hose) had scale build up that reduced inside diameter to around 20mm!
Unfortunately I did not have a new diverter valve so cleaned the hardened scale off the old one and refitted it - mistake no 1!
Last week the valve jammed solid and couldn't be turned and then the handle broke off! New valve ordered.
Today I fitted it and no big surprise that the cause of the problem was once again a build up of scale. However to my consternation I noticed that the inside of the new pipework was also showing a build up of around 2 mm of scale deposit - just a few months after installation.
However I did notice that this scale deposit has not yet hardened - it is 'slushy' like wet sand really and can easily be removed with a stick or similar blunt instrument - ie it does not have to be chipped away.
Now, we have always subscribed to the 'if you don't eat it don't flush it" school of thought but I am now seriously wondering whether we would be better sending the odd 'wad' of toilet paper down the pipework to act as a 'pig' and clean the pipes out? Is this a foolhardy idea? Shoud I try the brick-acid approach instead?
One of the design faults to add to the problem is that the boat (US built) was originally made with just a holding tank and the valve and outlet to overboard is an add-on for the European market. as a consequence the entire length of hose between the valve and the seacock is below water level and thus presumably remains full of seawater at all times.
This may have an upside, in that this is maybe what prevents the scale going hard? I noticed that the pipe from the valve to the holding tank - which of course drains into the holding tank - has no scale.
By the way does anyone know what causes this deposit. if you put seawater in a glass the sea salt doesn't precipitate out so presumably it is a reaction between urine and seawater? I go to some lengths to give plenty of strokes to pump out so it is pure seawater in the pipes but i guess the deposition and precipitation occur quite quickly.
I ay have to pee in a bottle of seawater to find out!
Thanks in anticipation
