scaffolding pole ID
Heckler
24 Feb 2003
does any one know what the ID of scaffolding pole is? have searched with google but nowt comes up. need 8 ft pole to mount my ampair 100 on and need 38 mm hole to shove it in
stu
<hr width=100% size=1><A target="_blank" HREF=http://www.beneteau-owners-association.org.uk>http://www.beneteau-owners-association.org.uk</A>
johna
12 Aug 2001
Poole
48mm OD so near enougth 38mm ID but bl***y heavy try stainless thin wall tube with bracing.
Jools_of_Top_Cat
16 Dec 2002
Telephone a builders hire shop; they will tell you straight away I would have thought.
8 ft is very high, can't you kink the pole and have it overboard on the transom? It is only aesthetic I guess, but most poles are only 2m tall when you get them from the manufacturer. Have you also considered stainless it might not be as expensive as you might think......
<A target="_blank" HREF=http://www.marine-hardware.co.uk/acatalog/Sea_Screw_Catalogue_Tube_Stainless___Aluminium_39.html>sea-screw stainless tubes</A>
They do not have 38mm but they may be able to get it?
Just a thought…..
<hr width=100% size=1>J
<A target="_blank" HREF=http://www.topcatsail.co.uk>
</A>
longjohnsilver
30 May 2001
Yes agree with others, try a scrap yard for dirt cheap stainless tubing. Much lighter and will look better.
StugeronSteve
29 Apr 2003
Not always where I would like to be!
Phone a few dairies/breweries etc and ask for the engineers. You should be able to scrounge some suitable s/s dairy tube. Much, much lighter than scaffold tube and a lot better looking.
<hr width=100% size=1>God only made so many perfect heads. The rest got covered in hair.
snowleopard
Oxford
the stuff you're after is called 'schedule 40' tube. i have some in aluminium for my air marine generator. the OD is 47.5 and ID 39.5.
i had a hell of a time finding it as i phoned the firm recommended and they said they didn't sell it. in the end i found out that they don't sell 'pipe' and i should have asked for 'tube'!!
john_morris_uk
3 Jul 2002
At sea somewhere.
I confused about the diameters quoted as I have recently been sorting some rails out for my Cricket Club. I was going to use scafold pipe with those fancy connectors that you see on handrails (the ones with allan grub screws in them) but was firmly told that scafold was 2" (ie 50.8 mm) and the tube for the conncetors is 48 mm and not compatible.
I used scafold in the end with scafold clips and won't bore you with the health and safety man's conversation about where our 'scaf tag' was...
graham
Ridiculous IDea I cant see everyone carrying 8 foot scaffold poles aropund in there wallets???? {:)
On a serious note what about alluminium tube?much lighter than mild steel and easier to work with than stainless.
snowleopard
Oxford
yes, that's what i have. scaffold pole is available in aluminium and, judging by its condition after 4 years, it's anodised.
Heckler
24 Feb 2003
them that can do, them that cant, teach !
engineers in the context of tubes recognise that id means internal diameter,
stu
