Monique
These are the ones we have.
http://www.asbikes.co.uk/electro-bike-mk3-9-p.asp
Bought our first ones (two) 5 or 6 years ago.
Then we bought two more a couple of years ago.
They are cheap Chinese imports but the quality is good enough.
We've had a couple of failures/breakages but fixable.
The early ones came as two models - 24v and 36v - we chose the 36v ones and don't regret it.
They have changed slightly over the years - mostly all good improvements - batteries have stayed the same so all ours are interchangeable.
They are not the lightest of bikes around but IMO really great value.
IMO, the most important thing to consider when buying electric bikes is that they must have an option to operate without actually pedalling.
Ours have three position rocker switch which naturally sits under your thumb when riding.
Switch between OFF - All Electric - or Assist
With it set to all electric then you can use a twist grip similar to a motorbike
With it set to assist, it helps you pedal.
Mostly, I use the "All Electric" mode and help it by pedalling.
The salesman/owner of As Bikes said this is a technique he calls "blipping".
Basically you ride the bike conventionally and "blip" every now and then.
That way you can get as much as 25 miles out of a battery (on the flat)
If you are going to use them on the boat - a couple of points
1
THEY DON'T WORK AFTER THEY HAVE FALLEN INTO THE WATER - completely dead.
We haven't done so but we do know of someone who has.
2
If you buy them be sure to pay extra for the pannier bags that fit over the back wheels and the canvass handle bar bag.
Using this arrangement, we very often empty a complete shopping trolley into two bikes.
We then cycle the bikes right down to the boat before offloading.
They also sell storage bags that the whole bike fits into when they are folded.
We only have two of these bags and are regretting that we didn't buy two more bike bags.
So - Yes we would buy them again - indeed - we did!!
BTW AS Bikes aren't really into doing deals - you might get some of the bags and some carriage thrown in if you are buying two bikes but generally speaking they don't discount.
As I have said above - these bikes are some of the best things that we have bought for the boat.
We use them everywhere.
Thank you to Bart, MapisM and Hurricane. I will look you up when passing through Sardinia in July. Expect a lovely big "raggy" in your raft. We carry more wine than any of you... storage space for 144 bottles. Boat name is Eleuthera, a 53 foot Amel Super Maramu.
