VicS
Just sold a merc that I used constantly for ten years & never flushed once.
Moral of this story: Dont buy a used outboard from kristifercolumnbus .
The purchaser seemed very happy no complaints
By the way I gave him some very good advice on how not to go wasting money on thermostats![]()
If you want to shift the deposit, use phosphoric acid, that really does work and aluminium phosphate is fairly stable (its the etching material used before painting an aluminium assembly) so it won't damage the aluminium engine castings.
Hadn't noticed the date but someone may still find the information useful as hopefully engines will last a long time.
We have a Mariner 2 hp outboard, and I mentioned to my wife that there were several items in PBO about the problem of salt deposits in the cooling systems of small outboards, and the difficulty of removing them. There is a council of perfection that says you should run the motor in fresh water each time you run it in the sea, but I suspect that is more honoured in the breach than the observance, especially when returning to the mooring on a wet Sunday night.
Anyway, she said there are chemicals you can add to everything from kettles to toilets to remove limescale, and wasn't there something you could use in water every now and again to remove salt deposits from outboard's cooling systems? I don't know. Does anyone have any ideas?
One problem is.............
