Hardy Mariner 25? I think that’s a stern driven boat (maybe wrong) or a trusty, I know there displacement boats so probably won’t get the speed but they have bilge keels so if you dried out the boat would be upright.
What is WAFI.
Sorry, couldnt resist but age and creakiness means we are coming to the end of our sailing, and to fend off any daft ideas SWMBO might have about caravans etc, I am contemplating buying a small stink boat. But I know absolutely sod all about them so I need advice.
We are based at Cardiff and sail the Bristol Channel which has few marinas and rather more harbours drying either to soft mud or to hard sand - so I would like a boat that can dry out. Its not an area for outboards IMO ( been there) - what is needed is a reliable diesel. 20kn max would be acceptable. Maybe 26ft or thereabouts with a couple of cabins , a toilet, heads, cooker fridge . No flybridge but an aft area that is a bit like a patio because in reality I suspect it wont go very far and will mostly be a floating caravan.
Budget? I would like to be below £50k because thats what my yacht is likely to fetch. Suggests something older. Pal has a 26ft or thereabouts Sealine from the 90s which looks like a possible.
Agree with the level of hostility, can’t understand it??It’s a shame about some of the hostility you received.
Anyway I’m assuming you’ll keep the boat floating in Cardiff bay somewhere and want to visit places like watchet.
An out drive boat if you want a diesel will serve you well. A sea line S28 or, if you can afford it, an S34 would be a good place to start looking.
An outdrive has the engine in the boat and the outdrive is like the bottom half of an outboard and sticks out of the back of the boat.
Outdrive pros for you.
Low fuel burn (but it will seem huge to you anyway)
Ability to raise the leg and reduce draft if it’s very shallow.
Ability to raise leg and dry out. You’ll be level on mud and lean a bit on sand but just pretend it’s a beam reach. (You could get short legs to stay level if you regularly dry on sand and it annoys you.)
Kicks up if you hit the bottom so hopefully little damage.
Ability to raise the legs and reach the props to keep them clean or remove rope fouling etc. Clean props make a HUGE difference on a mobo.
Much more fun and engaging to drive than a shaft boat.
Cons of an outdrive.
Regular maintenance is absolutely vital or they’ll bite you in the wallet.
Servicing more expensive than shafts.
Good specialist survey and or full history vital on purchase.
Some people say they are harder to handle Than shafts but this isn’t true. They are however very different to shaft drive and you need a lesson from someone who knows outdrives.
Start a new thread when you find a boat to look at and hopefully it will be better received.
The S28 will involve turning the dinette into a double plus an aft cabin the S34 has 2 separate cabins plus the saloon. It’s a lot more boat but will be more money.
Good luck.
Good luck.
All good choices, I’ve owned a CI32 and loved it. And we have an AquaStar as our dive boat, again a good boat. And Nelson have a superb reputation, but tend to provide less living space due to their narrow beam.Coming over to the dark side, H?It does sound like what you need is a boat specifically designed to take the ground which immediately disqualifies most planing boats. If you really want to stay upright on a drying mooring, you'll need a boat with a keel and possibly drying out legs fitted to stop the thing falling over.
The kind of boats that immediately come to mind are Aquastars
Aquastar 33 Used Boat for Sale 1992(SOLD) | TheYachtMarket
Channel Islands
1990 Channel Island 32 Power New and Used Boats for Sale -
Nelson
1984 Nelson 820 Power New and Used Boats for Sale - www.yachtworld.co.uk
Is that an enclosed flybridge model.One of these? If you're not fit enough to sail a 'stink pot' is not going to be much good to you for very long
Or alternatively don't start a thread of by insulting the people you want advice from.
I didn't take it as insulting I took it as tongue in cheek humour.Or alternatively don't start a thread of by insulting the people you want advice from.
A smaller botnia is indeed an excellent choice and worth considering.First thing to appreciate is your nose will not bleed if you exceed the dizzy heights of six knots!
For those taking offence at the op, chill and look for your sense of humour.
I suspect you will need a bigger boat for what you are looking for and maybe a bigger budget. Is Broom not the normal make recommended to raggies seeing the light?
SD on a prop may be able to dry out ok but some have exposed prop and rudder. A sports boat may be the cheapest way to get more or less the space at more or less the budget. Will use a lot less fuel too. For a lot more money a Botnia Targa 30 upwards (and similar) will give two cabins with a lot of deck space.
I will now forever have a vivid image of what a group of motorboaters look like when gathered in a bar.I was thinking the same. It would be a bit like going onto a gay forum and announcing that you don't really like the idea but reluctantly accept that you might be that way inclined. Although you can't see yourself beinbg friends with any of them.
Been there, done that. Admittedly it was a Prout which is a good boat but really a motor sailer, and a boat where you put on the autopilot passing through the harbour entrance.A catamaran would work well at not rolling over.
You are not going to get a lot with the budget restraints , Prouts perhaps , good livesboards , dont need to use the sails ?A catamaran would work well at not rolling over.
Thanks Bruce. I am marina based but who wants to stay in the base all the time. Trouble with the B C is that there are only 2 decent marinas between Cardiff and Lands end - Swansea and Portishead. True there is a silted up one at Watchet and a tiny one I have yet to visit at Porthcawl plus there is Milford haven. But there are lots of nice little drying harbours thast I visited when I had a cat and a bilgie and would like to visit again.You lot should be more welcoming. The man has finally seen the light and it's taken him a lifetime to do so. Just goes to show it's never too late.
I agree with Deleted User. Outdrive and or planing hull drying out is never ideal but possible with beaching legs. Just look to Guernsey for evidence of that. The downside is every word I've heard is that lying on mud plays hell on AF effectiveness and a few spotty growths on a sailing boat is acceptable but on a planing poat can completely ruin your day. So if you are Cardiff based have a look at one of their marinas / other side the locks. Not all berths are overly dear.
Gosh, you lot are sensitive. I'll have you know that some of my best friends drive stink boats.I was thinking the same. It would be a bit like going onto a gay forum and announcing that you don't really like the idea but reluctantly accept that you might be that way inclined. Although you can't see yourself beinbg friends with any of them.
In our club there are a group of older Gents (&Ladies) who all retired their sailing boats, they all bought Seaward 23's and 25's. One of them is in his 90's.
Gosh, you lot are sensitive. I'll have you know that some of my best friends drive stink boats.Others are WAFIs.
Thanks Ferris. Being a bit more serious, those are a bit more "Nelson" than I was thinking. The mobo that an ex sailing pal has just bought ( same reason as me)) has a much more protected cockpit for SWMBO to sit out in.
