Mogz77
Hi All, just like to introduce myself, and ask if there is a dinghy group on here ?
You maybe don't remenber being 'more bulky' or being less agile. I found a Solo at 60 was a recipe for a dunking at least every other trip out.Just bought a dinghy again after several decades. Bloody thing tips up a lot more than I remember! ?
I'm hoping I can get the teenage kids sailing in it. A lot quicker (easier?) to learn that way than in a 5 tonne keel boat, I'm hoping.
Old two-man racing dinghies (assuming they're not actually damaged) are particularly appealing, being really cheap...because they're unlikely to win against newer examples that have had costly refits. The old ones can still be very good sound boats.![]()
Welcome to the forum.
Is your interest in dinghy cruising / pottering or racing (there may be better fora for the latter)?
The issue with bigger / heavier two.man dinghies, if sailing solo, is that one medium sized person may be too light to right them in a stiff breeze if capsize. Fine if crewed as designed
While anyone can capsize given enough bad luck, a bigger dinghy may be more stable, even when sailed solo. Much depends on the design too, with a hard-chined hull being much stiffer in a breeze. The ability to shorten sail is, I think, vital. Can you reef your mainsail? Will she sail well under main alone? Of course you could always increase moveable ballast by putting on a stone or two.![]()
I have just ordered a new mainsail with a second set of reef points and heavier-weight sailcloth. The ability to reef well down is an added safety measure if the winds pick up when your dinghy is in open water. My current arrangement is to roll the sail around the boom if more than one reef is needed, but your boat has to be set up for this. This was the standard arrangement when Ian Proctor designed her in 1957, but requires a reefing claw (which I don’t have) if you want to attach the kicking strap.I reckon it's largely a matter of approach. The singlehander who goes out in a boat designed for two, will be wise to take precautions.
I tie a float to the Osprey's masthead, and have fitted 'righting lines' to the gunwale that enable me to stand at the very end of the centreboard, leaning back to increase the righting effect when knocked-down. As far as I've seen, most two-handed race boats nevertheless rely on only one chap on the centreboard when there's a knock-down.
But it's true, the singlehander who launches an unmodified two-man boat in a moderate breeze, can be sure of being overpowered or frustrated. Preparation is the key.
Very few racing classes offer mainsails with reefing arrangements, but fitting reef-points or using a smaller than standard mainsail, plus a roller-jib or genoa, will dramatically tame a boat that is technically impossible to singlehand in a breeze.
Pity my halved mainsail isn't visible in this poor pic...it was gusting 18 knots. I had a cup of coffee, unspilled, on the floor.
Racing crews, bless 'em, are apt to be scornful of such standard seamanlike measures as reefing, in a dinghy. That's unfortunate (and deserves to be ignored) because there's a huge amount of fun to be had...
...as Madrigal remarked, a big dinghy with reduced sail rides more easily in rough water than a hard-pressed una-rigged boat that is deemed ideal for the singlehander. And in lighter winds, racers will be overtaken by 'cruising' boats carrying full sail whilst not burdened by the weight of two crew.
Retrofitting the versatility of a cruising-boat's reefing to a racing dinghy, greatly broadens the range of its use. It's fun.
Of course, not one word of that will interest Mogz77, if he's asking about getting into racing. But this isn't a racing forum.
No real ballast to speak of.
...the Leisure 17...you can probably buy one for less than most dinghies...
