Slipperman
Just replaced my saildrive seals/diaphragm and now need to finish the job by replacing the outer rubber fairing/streamlining. Would be interested in views on the best adhesive to use.
I used Sika of some sort, sticky bondy one.
I used black Sikaflex. I’ll find out soon if it’s still stuck!
I tried all sorts of adhesive & got fed up paying for new seals each year
I make my own from 3 mm rubber sheet, 2 euro's instead of 180.
Make sure to make cuts (with a round hole at the end to prevent tearing) in front and behind the sail drive so it can move back and forward under power.
Otherwise the rubber will be torn off.
I was off by a bit:
https://www.marine-power.co.uk/yanmar/saildrives?product_id=319
