TonyS
I think that the water intake in the saildrive actually sucks the water out of the seawater cooling system when sailing fast. I have been trying to understand the delay in the flow switch closing which is situated under the Vetus antisyphon valve. The pipes are now clean and see through and you can see the water dissapearing. If the boat is heeled a lot, lowering the seawater filter then I believe it sucks all the water out and leads to impeller failure. Or can there be another mechanism or hypothesis?
