fisherman
I had a lot of advice about basic setup for my ad hoc rig on the 15ft dredging punt, gratefully received and effective. What about this jib which I have tried, with the balanced lug? It is awkward tacking, the sheets are outside the forestay otherwise the sail fouls the gaff. It seems to upset the main being so close, it fills behind the luff. It doesn't seem to help with going about which is tricky unless the windspeed is within a very small window. Basically, main only, if I get it right she will come head to wind, just, then I push the boom out and the wind presses against the mast, she sails backwards for a bit then we're off again. I often have to gybe. Long straight keel, no dagger board.
is it just too close and the mast should be moved back, or a bowsprit fitted?
She sails nicely under main alone so I'm not sure the jib is helping.
![Photo0362[1].jpg Photo0362[1].jpg](https://ybw-data.community.forum/attachments/88/88786-d216f0f39505278c27cfe55ffa0f02a5.jpg?hash=0hbw85UFJ4)
