Mistroma
Side loading on cradle
Aerodynamics is certainly not my field but I wondered if I could get a rough handle on the loads involved. Ignoring the effect of sudden changes in load, the worst case scenario should be with the hull at 90 degrees to the wind.
I have a spreadsheet I used ages ago to get some rough figures for likely forces on a mooring. I took out factors relating to shear, wave action etc. and just left the basic calculations.
Boat: Jeanneau 42DS
Est'd Cross Sectional Area 33m2
Drag coefficients:
Flat sections of hull, rudder & keel guestimated at 0.9
Curved section at stern & below waterline approx. 0.7
Mast, boom approx. 0.6
Rigging approx. 1.0
This is the fuzzy area as drag coefficients aren't really fixed, vary with 3 dimensions not just CSA and I'm only making a guess to start with. However, I doubt any would lie outside 0.6 - 1.1 so figures should be in correct ballpark. Hopefully, someone with more expertise might be able to correct some of my assumptions.
Wind(kn) Drag (kg)
10 42
20 168
30 377
40 670
50 1047
60 1508
70 2053
80 2681
90 3393
100 4189
The calculation is very simplistic and just assumes that the wind is pushing the boat sideways. Obviously there will be leverage from a high mast & rigging and these accounted for around 12% of the final figure. However, that hasn't been factored in to the figures.
As the wind at the boatyard probably peaked near 80kn that would mean approx. 2.7 tonnes of force pushing the boat sideways. CSA on 3 support pads on leeward side might be around 300cm2 and that gives a point loading of 9 kg/cm on the hull.
Of course it need not be evenly spread and even so still works out at almost 1 tonne per pad.
Unless I've made an error somewhere it does look as if side loads can be measured in tonnes.
Now that I've arrived at a suitably scary big figure there's good news for me to consider before I go down to check the boat.
1) The wind should only have been side on towards the end of the bad weather
2) The boat is surrounded by others and so not exposed to the full force of the wind (probably more like 10%-20%).
So no hull damage with any luck but I imagine the windex and anemometer might not have survived. Meant to take them down before craning out but forgot (make note for next year).
Boat: Jeanneau 42DS
Drag coefficients:
Rigging approx. 1.0
Wind(kn) Drag (kg)
10 42
20 168
30 377
40 670
50 1047
60 1508
70 2053
80 2681
90 3393
100 4189
