vyv_cox
Hot water shouldn't be a problem, why not fit a calorifier?
I have had a Sadler 29 for 13 years. My first boat and never looked back, it has never let me down in some strong winds it's always the crew that give up before a Sadler.
Wiring can be an issue but one can re route with a little imagination, the foam keeps the boat warm and dry so winter sailing is also a bonus.
If you can live with a fin keel mine is up for sale. My partner is keen to do some long distance stuff in our retirement but wants the luxuries of life like hot water etc so it's time to pass the Sadler on.
It will be a sad day when she goes.
Delbuoy
here's our BK sadler 29 - isles of scilly 2014
we manage with cold water or use a kettle or sunshine!!! (if that happens)
cut out bottom of under cockpit storage and re built with flat surface -much more useable - had to do as new engine meant slightly different position for water trap which stopped bathtub fitting !
The phrase about parts of the engine setup reminded me that early on I moved the engine instrument panel on our S29 from down below to the aft facing side of the bridge deck. Not difficult to do and gives the helmsman instant access to engine starting and view of the rev counter.
I made a shallow wooden picture frame which had the instrument panel recessed into it and then made a fixed Perspex window which left a sufficient gap at the bottom to allow the key to be inserted and operated. When the key is not in place I have a second window of Perspex which can be slipped up and behind the fixed window and this is retained by two s/s round headed screws which are set in the bottom rail of the picture frame with enough protruding to hold the loose window. That window has a cutout in its lower edge to allow a finger to be hooked in in order to remove it. A rectangular cutout in the bridge deck face allows all but part of the picture frame to be recessed. It's proved to be weatherproof ove around 10 years now. The nice thing is that the revised position of the panel is so close to the original position that no wiring mods were needed - simply turn the panel through 180 degrees. I didn't move the cold start control as that looked too difficult but I find that as long as the VP 2002 has run once during the day then it doesn't require the cold start control to be operated.What did you do about waterproofing? On the 34, which is pretty similar in many respects to the 29, the location you mention is completely open and does not lend itself to a Perspex cover. I have a tachometer there, which seems to be surviving, but I'm not sure the Yanmar engine panel would.
That bit surprises me as my S29 has the prop shaft offset to Port to permit withdrawal. I assumed that that was general for the model. I've speculated also that the offset must cancell out some propwalk when going forwards.Hi Reac, one thing I hadn't bargained on was the engine and shaft fittings of the old engine also a Yanmar 1gm10 were dead in line with the Skeg which meant The engine would have to be moved forward into the cabin to replace future Cutlas bearings. However, my engineer has made a puller so the bearing can be tapped little by little out from its housing and down the shaft and off when the prop is removed.
That is all really with reference to engine parts!
Cheers, Kevin
I've only come across this on a friend's 32. When the boat was newly acquired, the shaft became disconnected from the gearbox and they were lucky that the two-bladed prop hit the rudder and didn't disappear altogether.That bit surprises me as my S29 has the prop shaft offset to Port to permit withdrawal. I assumed that that was general for the model. I've speculated also that the offset must cancell out some propwalk when going forwards.
My 1987 29 was certainly not offset and was factory built, in fact, we went to see it being built. There were a number of changes during the production run. I think you must have only been seeing earlier models.Mine (1984) does too .... as well as every other S29 I have seen.
However yachts build by the original company were available to any desired state of completion, so a home builder might have done things differently. (Also a few were built under license in South Africa, may be different, and may by now have ended up over here in UK).
Hello GPS2, I did not buy a 29, rather a 26, also a bilge keeler, mine came from the East coast but has had a chequered career and went on holiday to North Wales which was where I found her. I had wanted a Sadler for some time and as others have intimated, a survey is a good idea. Mine showed osmosis and would require something doing to the topsides which had been painted ten years ago.
These boats were very well built,have a good name and hold their value well so in my opinion as a young classic boat are well worth considering not only as a project but also for ownership. I have done a great deal to mine including new standing and running rigging, a new engine, full osmosis treatment and the topsides are now vynil wrapped as many race boats. To do all this properly the boat was a year ashore during which time I also replaced my pillow water tank and made alterations to suit me internally and to some parts of the engine set up and recently added a full width stern rail with a solar panel on.
Many people take many years to renovate their boats, I wanted most to be done in the year and now she is afloat, that double skin build is proving its worth as the boat is dry and never cold even without a heater, I am very pleased.
Yes, do join the Sadler and Starlight Association and use the forum as all information re your 29 can be asked for there.
Go for it, I doubt you will be sorry!
All the best
Kevin
I read somewhere recently that " A well executed passage is often better than arriving first"
