stuartwineberg
Which exchanger?
Very interesting. However we did strip the raw/fresh exchanger down, took the coppoer tube stack out and gave it all a good clean. I don't recall this goo. There was more gunge in the air charge cooler for the turbo and I still think I may not have cleaned the fins on that one out as thoroughly as I would have liked basically cos it was so big. We definitely checked no blockage in the tubes on both and cleaned out the castings completely - have I missed something?
Stuart,
Spent the weekend with owner of marine services company who had stong ties with Sabre in Poole.
As soon as I mentioned your problem his response was immediate. Ten degree rise in operating temperature, Problem well known to Sabre guys..........Strip the heat exchanger, and take tube stack out. You will find engine coolant side of heat exchanger coated in a gooey slime. Apparently slime results in long term reaction of coolant with chemical treatment used by the foundry who cast the heat exchanger body. Once the tube stack is 100% clean and cooling system completely flushed engine operating temperature return to normal and issue never returns.
Good luck
