S/S Duo Props
KevB
4 Jul 2001
Kent/Chichester
Was going to buy some last year but decided to make the ally ones last another season. Fortunately for me they just made it but now I need to buy some new props and am going for Stainless Steel.
From what I recall from a previous thread Peter's were the cheapest, anyone been able to get a good deal on S/S Duo props elsewhere?
Kevin.
KevB
4 Jul 2001
Kent/Chichester
Haven't the pair of you got any work to do?
Thinking about it.....I know a Sealine with S/S props fitted.
Must remember to take my dry suit to the marina this weekend!!
Vagabond
22 Feb 2005
Auckland, New Zealand
www.flickr.com
Re: welcome.....
Thank-you for the Welcome,
I'm sure he would if his wife would let him .... !
Problem is if he goes stainless he'll probably go even faster and have even more opportunity to blast passed me! As it is I have to leave 2 days before he does and that's just to get to Poole!
duncan
Home mid Kent - Boat @ Poole
Re: welcome.....
Ah but you can just sling your hook in Studland or Poole Harbour and run ashore in the tender whilst he will still be negotiating a berth in Dolphin Haven!
About 4 hour run for you?
May well see you around this summer ? - if you bother to go that far!
Vagabond
22 Feb 2005
www.flickr.com
Re: welcome.....
Too true!
Either Studland (if I can get the anchor to hold!) or at the back of Brownsea/Goathorn Point.
Yes about 4 hours. When the sun is out it's a really relaxing trip, autopilot on, sopt of lunch on the way over and a kip on the bow .... roll on Summer!
KevB
4 Jul 2001
Kent/Chichester
Re: welcome.....
I would have thought that now you don't have to factor in the dog you would have changed your steamship for something a little more racy?
Although I must admit it's a fine steamship. That is steam bellowing from your engine bay when your underway isn't it? /forums/images/graemlins/laugh.gif
admillington
25 Oct 2001
Winchester/Lymington
I installed a set of Stainless Steel props to my Sessa 36 fitted with KAD44s. Without question it improved the performance a lot but I did go down a pitch on Richard Bates recommendation - someone to do with them being less flexible.
Now the downside - you will be shocked by the how fast the leg anodes disappear - you might have to lift the boat out mid season. I had additional anodes installed on the leg fins, and doubled up on the ones on the base and this helped. I also installed a Zinc Saver in the earth line - I have one of these spare if you want to give me £20.00 for it.
I am on S19 and hopefully will be down at the weekend if you chat over my leg erosion experiences on the Sessa and Targa 40.
Dave_Snelson
16 Oct 2001
Porthmadog / Port Leucate
www.makeyourowngarments.com
From a performance and aesthetice point of view, SS is fine. From a marine engineering point of view, no way. If you fit SS props beware of anode erosion and....if you ding the prop you will write off your drive drain instead of just the prop. You have been warned! (in a friendly way, of course!)
[2068]
19 Sep 2002
- would have thought that it would take more than a "ding" to wreck the drivetrain: more like a "crash" into something hard at speed, but it's a valid point, that alu props will absorb more of an impact than SS before the gears get crunched.
dv.
