RUTLAND WIND CHARGER
Has anyone fitted a Rutland 503 to an Etap22i - what's involved? - advice appreciated
I've recently mounted a 503 to my Centaur and that was fairly straightforward. I assume you have the standard mounting kit and a suitable regulator. The only problem I had was that after mounting the post very firmly to the aft coaming and, using a galvanised bracket to strap the post to the push-pit, I still found that the 2 metre tall post flexed at the top with boat movement. I have rigged wires from the post to the backstay and also to the deck to limit this movement and all seems well. It survived the exciting weather that hit us during the transit from the Needles to St. Catherines Point without complaint.
Regards
Tom
